LMS4.1 Problem with calculation of Interface Utilization
Werner Siewert
Dear All,
we have configured LMS to send emails when Interface Utilization is higher than 40% (default Threshold).
The mails look like this:
EVENT ID               = 00012QS
TIME                   = Wed 07-Nov-2012 03:03:54 CET
STATUS                 = Active
SEVERITY               = Critical
MANAGED OBJECT         = h-a45-c1.nlfb.bgr.de
MANAGED OBJECT TYPE     = Switches and Hubs
EVENT DESCRIPTION       = HighUtilization::Component=PORT-h-a45-c1.nlfb.bgr.de/8.7 [->cisco WS-C3560G-48TS] [H-F133-b311-C118-gi0/52];ComponentClass=Port;ComponentEventCode=1057;TrafficRate=5.0246484E7 BYPS;DuplexMode=FULLDUPLEX;UtilizationThreshold=40;MaxSpeed=1000000000;Ty
CUSTOMER IDENTIFICATION = notifivation_group_01
CUSTOMER REVISION       = 01
NOTIFICATION ORIGINATOR = Fault Management Module
But now I have a problem with the calculation of the TrafficRate:
TrafficRate=5.02464...E7 = 5.024 x 10 exp 7 = 50.240.000 bit/sec??? but 50Mbit/s are only 5% utilization on 1GBit Interface...
If someone can help with this calculation?
best regards
Werner
Martin Ermel
there is one mistake in your calculation, on duplex interfaces the TrafficRate is the sum of ifInOctets and ifOutOctets (on half-duplex it is the max value). In both cases the value is given as octects, - to get bps you need to multiply with 8. To convert to Mbps you have to divide by 1000 000, thus you get
TrafficRate=5,0246484E7 (sum of ifInOctets and ifOutOctets)
in bps it is :
5.0246484 *10E7 *8 = 401971872
convert to Mbps:
401971872 / 1000 000 = 401,971872
all together:
5.0246484 *10E7 *8 /1000 000 = 401,971872
401 Mbps is 40,1% of 1Gbps (= 1000 Mbps)
thus, the event is correct.
Martin Ermel
in bps it is :
convert to Mbps:
all together:
Thanks for your help, Martin!
