LMS4.2.4: trouble with UT Application
STEFFEN NEUSER
Level 4
Level 4
User Tracking isnt useable at all:
1. if you jump from (nnn End Hosts)@Collection Summery you get a Notifiaction Window: "Error in loading properties from the server" in place of the expecet UT-list.
2. if you call UT from reporting, you will wait very long time to get the mask and after calling a quick report you get a Notifiaction Window: "Application Error: ."
3. there is nothing seen in all log files during calling time period
Steffen
P.S.: pdshow showes ANIServer is stutdown, pdexec shut the ANIServer down 1 minute later, ani.log showes: Could not create socket (43242) ... BindExepion: Adress already in use: JVM_Bind
STEFFEN NEUSER
Level 4
Level 4
Reboot solved the problem
mohamed louhab
Hi ,
Thanks sneuser.
i was had the same issue and the restart solve this problem.
thanks you
