LMS4.2: Empty Device Selector in Reporting
STEFFEN NEUSER
Level 4
Level 4
In LMS4.2.0 Device Selector is overall working except of the whole reporting with always 0 devices selected. Do you have any ideas what to can do?
thx for hints, Steffen
AFROJ AHMAD
Hi Steffen,
Try to Reboot the server and check the issue again.
Your LMS is Installed on which OS ?
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
its a Windows system
Steffen,
follow the below steps:
1.stop the daemon manager
2.Remove or rename the RME database transactional logs (rme.log) (if they exist):
# NMSROOT/ CSCOpx\databases\rmeng\rme.log
3.
NMSROOT/CSCOpx/database/rmeng> dbsrv10 –f  rmeng.db
4. start the daemon manager
wait for 15 mins and check the issue again.
Thanks-
Afroz
Hi Afroj,
Thx for the procedure, but it doesnt fix the issue.
I also upgraded to LMS4.2.4, no improvement, cant use overall reporting.
Steffen
