LMS4.2 minor upgrade to PI12
janvandek
          Dear,
I would like to upgrade LMS4.2 to PI1.2. According to Cisco this is a minor upgrade (requires the SAS code) and can be downloaded from the Cisco portal for free. My question: Can I still reuse the license and the B2B cisco support I use for my LMS4.2 ?
I will also upgrade WCS7.0.x to PI1.2.  Will there finally be 1 server running 1 merged software, or will there be 2 servers one for WCS >> PI and one for LMS >> PI ?
REgards
Jan
Marvin Rhoads
It's generally not recommended to "upgrade" LMS 4.2 to PI - you will lose functions as PI is not yet at feature parity with LMS.
WCS can upgrade to PI.
If you really really want to combine your installation onto a single PI server (no LMS, additive license count), I believe you will need to work with the TAC to get the licenses issued accordingly.
