Load Balancing b/w two cisco router
Hello Friends,
Please advise me,We are using two Cisco Routers with F5 Load balancer,
Router A (Cisco 2811) has one ISP configured
Router B (Cisco 3825) has the other ISP configured
ISP on Router A has 5 Mbps Bandwidth
ISP on Router B has 10 Mbps Bandwidth
My Doubt is if the load balancer is down,how to utilize the ISP (or) How to divert the connection ?
Here i have attached my N/w diagram for ur reference..........
Can someone solve my question.............please
Thank you.
sathvik k v
Level 3
Level 3
Whats the routing protocol used??
Sathvik K V
Hi friend,
Default Routing is used in my network.
Hi Mohamed,
With default routing in use you can just configure one default route on each router   But it would only do load sharing not load balancing.
PFR(performance routing) is a better solution but have never tried with two diffferent router series. Also need to validate if the router series you are using supports PFR.
Sathvik K V
