logging?
p950mte
Hi there!
A short question about (sys)logging to LMS, for most routers and switches logging to RME works:
Logging buffer size: 500
timestamp option: enabled
Logging history size: 1
Logging console: enabled
Logging server: enabled
{xx.xx.xx.xx}
server facility: LOCAL7
server severity: warnings(4)
Current Logging Session: enabled
for some reason this device 5500 Switch doesn´t.
LMS/ RME gives the answer back: Please check whether logging has been enabled on selected device(s).
I have no filters applied or haven´t done anything different with this dev., has it got something to do with versions on the dev?
Mats F.
m-ko
Level 2
Level 2
Perhaps, you really do not have any logging message above or at the warning level. Try to change the server severity to informational first to test your 5500 can receive any logging.
