Looking for Script for Auto login to router via ssh & command output
accenture-bang2
                   Hi expert,
I am looking for some solution.
We have around 8 router, everyday twice,we need to login(SSHv2) to each router runc 2-3 command(Ping some interface for Latency checking,router uptime)
I am looking for some script/tool so that work can be minimized/aitomatic.
Something Like auto login to router, command will run automatically & output will be showing on screen/some batch file kind of output
Pls suggest script/toll for the requirement
Sandeep Choudhary
Hi Bang-2,
If you are using Linux OS then :
it should work :
#!/usr/bin/expect
set timeout 20
spawn telnet 10.1.1.1
expect "Username:"
send "test\r"
expect "Password:"
send "test\r"
expect "*#"
interact
exit
Please rate if it helps.
Sandeep Choudhary
Hi Bang-2,
it should work :
#!/usr/bin/expect
set timeout 20
expect "Username:"
send "test\r"
expect "Password:"
send "test\r"
expect "*#"
interact
exit
Hi..
Pls share in case of Login from Windows xp /vista system
