management console Cisco UCSB-B200-M3
cb122cb122
Are there any free tools that come with Cisco UCSB-B200-M3 servers which could do a quick management freindly healthcheck report/check settings of the server against best practice.
cb122cb122
surely somebody can answer this? Or arent these forums particularly active/monitored?
AFAIK , unfortunately there is no free software with this UCS server  like CNA .
If someone has a different view , share with us.
Thanks-
Afroz
****Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I'm with Afroz on this - no freeware for the UCS servers as far as I know.
The network management forum is quite active but we're generally not as deep in data center-specific expertise here, even less when you get into the UCS servers.
You may want to recategorize your post into the Data Center > Unified Computing forum (via the actions widget in the top right of your screen) for better UCS insight. It's not as active as this forum space but the folks who frequent it would be more likely to weigh in decisively in this area.
