Merging Subnets
lmsaeb123
Community Member
I am looking for some advice. I have inherited two networks - 192.168.70.0 mask 255.255.254.0 and 192.168.80.0 255.255.255.0
I would like to merge these into one larger network by just changing the subnet. This is because there is a lot of infrastructure setup and I do not want to really change the IP addresses of hosts. Basically, I just want the devices on these networks to be able to be on the same network and talk to each other.
The problem I am having is figuring out what subnet I could use to accomplish this.
Thanks in advance for any help.
Richard Burts
Ashley
If you want to combine these subnets you should use 192.168.64.0 255.255.224.0
Rick
Rick
Richard Burts
Ashley
Rick
Rick
Thanks Richard
Ashley
I am glad that my suggestion was helpful in resolving your question. Thank you for marking the question as resolved (and thanks for the points). It makes the forum more useful when people can read a question and can know from the marking that there was a resolution to the question. By marking the question as resolved you have contributed to this process.
Rick
Rick
