MIB for Uncorrectable HEC Errors
Is there a MIB support for the Uncorrectable HEC errors on IMA bundles. The errors can be displayed with the following show command from the Router CLI mode.
R1#sho controllers aTM 5/1 | inc hec
chece - # rx Correctable HEC errors
hcs:28517, chece:0, uicell:39122, oocd:12044,
TIA
Sundar
Joe Clarke
The closest object I found is cimaGrpNumRxErrIcpCells which will give you the number of cells that has either a HEC or CRC error at an expected ICP location. However, I'm not sure if your IOS supports the CISCO-IMA-MIB from which this object is defined.
Joe,
I forwarded the info to the Engineer who was looking for an answer and didn't hear back from him at all.
Sundar
