MIB Nexus 7000 or 9000 for PRTG
leandroscotti
Hello everyone,
I've been searching for the MIBs for PRTG for the Nexus 9000 or 7000 series to monitor fans or power supplies.
The MIBs downloaded from the site https://cfnng.cisco.com/mibs don't work.
I’ve also tried downloading them from other sites, but none of them work correctly.
Can anyone tell me exactly where I can download them?
regards
Ben Walters
Level 4
Level 4
Are you just looking to find the OIDs for monitoring PSU and fans?
For the nexus you should be able to use:
1.3.6.1.4.1.9.9.117.1.4.1.1.1 - fans
1.3.6.1.4.1.9.9.117.1.1.2.1.2 - psu
I find this site much more helpful
Cisco SNMP Object Navigator
If you snmpwalk those OIDs you should be able to find the identifier for each instance if there are multiple PSU and fan modules.
