MIB upload failed
oizetbegovic
Level 3
Level 3
I've tried to upload MIB file into Prime and it failed. Prime just displays 'Error' when trying to import the MIB file. I've found a bug related to this error message (CSCtz77712) but it seems it was never resolved.
How do I know which dependent MIB is missing in Prime so I should import it also? Is there a log file where this could be found?
AFROJ AHMAD
which MIB you are trying to import  in Prime ?
Thanks-
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
CISCO-BGP4-MIB
AFROJ AHMAD
you can check the nms_launchout.log
hope it will help
Thanks-
Afroz
There is nothing regarding MIB upload in this log file.
