Migration PI 2.1 to 2.2 results in Error
lo.mueller
Hello all,
trying to migrate PI 2.1 to 2.2 (performing backup on PI 2.1, fresh install PI 2.2, restore PI 2.1 backup in PI 2.2)
after starting services we got following error in WEBUI
"Error in getting data from server. Make sure you have connectivity and the server is UP"
During the restore-process and starting PI-Application no errors were shown.
In idea what happened?
Thanks for your feedback
Lothar
Mark Elsen
 - Check :  (from command line)
                prime-server # ncs status
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Lothar,
It should be the browser issue.. try to clear the cache and check the issue again.
check the supported browser list and try again.
hope you have not selected the "FIPS mode" during installation \ upgrade.
Thanks-
Afroz
****Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
