Missing oids in Mib-2
anandmirasdar
Why are some oids from MIB-2 desupported in a certain IOS version ?
Where can I find the new/replacement oid in such situations ?
For example, in IOS version 12.2(18) IfInNUCast was deprecated.
David Stanford
If the MIB is deprecated, it will be deprecated in all IOS versions.
Which objects do you see as unsupported in certain IOS versions?
Some deprecated objects have been replaced and most times it lists the replacements in the MIB itself.
ifInNUCast is deprecated and replaced by two counters: ifInMCast, ifInBCast
