mls qos
Ralph Rankin
Hi Expert,
Any one can explain me what this is means? this is show using show running config.  thanks
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
crypto pki certificate chain TP-self-signed-675850496
 certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 36373538 35303439 36301E17 0D393330 33303130 30303131
  335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3637 35383530
  34393630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  AE3FE6E0 4AEF3AF3 027E624D 38F1A20B 613869E5 85E5B54B C4AA5E88 486EF85F
  D918E6C6 FC95E9BA 6819D537 00D3FEBB EBBCCB3A 24DF9FB4 B18E9F96 3EE89807
  866A7D9F 34952407 956A00BA BEB0E0D0 79B7E48E C87C3D3A 6A3349D0 37E6AA14
  4D4597CB 7AAC295E B41091DC 26D6F663 03912E56 DA33FED4 0AF6BF52 2BB530DD
  02030100 01A36930 67300F06 03551D13 0101FF04 05300301 01FF3014 0603551D
  11040D30 0B820953 57526F75 7465722E 301F0603 551D2304 18301680 14CC50DB
  28F91469 D709750F 4F6F0F61 AA559A39 BF301D06 03551D0E 04160414 CC50DB28
  F91469D7 09750F4F 6F0F61AA 559A39BF 300D0609 2A864886 F70D0101 04050003
  8181007F 13A6AB6B 2910C0C1 C346B01C 31FA3BC6 F8D99C06 1D2415CA 154F3B5F
  86D0322E 5D929AB4 B61BCDB3 3B0262E1 FD6B921C 7AA4C3ED 064D1BA2 F8DCD5A7
  380FF69A D005C361 F80127B1 003F82B1 5750BC51 BAF194FA 9EA7F12C 939478AC
  0C2C287E FCDDDCB9 41FF5106 ADBF084F 834CA88E EF5B37DD 7D1A924E 8D595474 D80D9D
  quit
Vinod Arya
It seems your device is configured for QoS (Quality Of Service).  QoS is disabled usually by default. While QoS is disabled, all frames/packets are passed-through the switch unaltered. For example, if a frame with CoS 5 and the packet inside the frame with DSCP EF enters the switch, the CoS and DSCP labels are not changed. The traffic leaves with the same CoS and DSCP values as it enters. All the traffic, which includes voice, are delivered on the best effort basis.
Typically, networks operate on a best-effort delivery basis, which means that all traffic has equal priority and an equal chance of being delivered in a timely manner. When congestion occurs, all traffic has an equal chance of being dropped.
When you configure the QoS feature, you can select specific network traffic, prioritize it according to its relative importance, and use congestion-management and congestion-avoidance techniques to provide preferential treatment. Implementing QoS in your network makes network performance more predictable and bandwidth utilization more effective.
For more details, you should check on Configuration Guide for IOS/Platform you're using. This existing thread would also be helpful for you.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
thank you sir. when i purchased the switch i never configure the QoS but its enabled. and i experienced dropping connection one my client computer. i'm using ubnt wireless bridge between two site and i suspected that some incompatible issue between ubnt and cisco switches. do i need to disable QoS since i do not use voice telephony?
Thank you.
It may be an issue when you don't understand what is configured and which Traffic is being prioritised on the switch. You try disabling this from the switch.
To disable the QoS functionality globally, use the no mls qos command.
I would also suggest to take a backup of your configuration before making any changes.
-Thanks
Vinod
