Monitoring a BGP route and AS-PATH.
andrea.meconi
Level 2
Level 2
Hello.
I need to receive a SNMP trap when a BGP route, received with a specific AS-PATH, disappears from routing table.
Any ideas?
Thanks.
Andrea
GERARD PUOPLO
You can use EEM for this. Check out the cisco beyond web site for sample scripts that may help you do this.
A company that I used to work for, www.magnus.net had a mature EEM solution for doing this for large network environments. They took a standalone router and using EEM turned it into a route monitor.  It would send out notifications when BGP routes of defined attributes like AS-Path diasappeared from routing tables.  It was driven by an excel spreadsheet as inputs. It was written by a super CCIE engineer.
