Monitoring a router via console port
mathieu.ploton
I've a router in a DMZ. I can access it through my administration LAN. One of the computer in this LAN is connected to it through the console serial port and when i need to administrate it, I make a remote connection to the computer and use hyperterminal. What I would like to do is to be able to monitor the router through this console port because I can't access it (snmp or telnet) through the network due to firewalls.
Ideally, i would like to generate snmp traps from my remote admin computer when router interfaces fall down.
Is is possible ? What kind of software would help me reach that aim ?
Thank you
aghaznavi
Level 5
Level 5
Through the console port you can manually see the device conditions through the various show commands , better automated solution is SNMP configuration.
srimural
Monitoring a router or a device on the console is not advisable. The interrupts the CPU needs to process for console logging is pretty high and can impact services if high error rate or anything to occupy the CPU happens.
Its always desirable to put in no console logging in devices.
You can connect a cross connect from the PC you are connecting the console to and do an SNMP reporting. This will be a standalone PC and do a RDC to the PC and monitor the SNMP rather than the console itself.
Certain NMS like SMARTS,Netcool etc are able to port the traps and snmp details to other management stations. So you can try that as well. But SMARTS and NETCOOL requires alot of investements.
Srinath.M
Cable&Wirless
+91 99809 30364
Thank for the answer,
What do you call a cross connect ?
Thank you again,
MP
Sorry for the confusion.I mean to tell connect a ethernet port on the router which is free to the PC and configure an IP connectivity.
Then host an snmp station on the PC and walla you are good to go.
Srinath.M
