Monitoring ASA Cluster (A/A) with Prime 2.2
I face a weird issue with Prime Infrastructure 2.2. We have few ASA 5545-X clusters (active/active), and I am unable to add them to monitoring. Regardless of which IP address I use, VIP or physical, Prime cannot properly log into ASA with SSH. I get the message "Wrong CLI Credentials". I can however do successful SSH from remote desktop (credentials are OK) or even Prime's CLI. SNMPv3 works fine. The Prime version is:
Version : 2.2.0
Build : 2.2.0.0.158
Installed Updates:
Critical Fixes:
        PI 2.2.3 Maintenance Release ( 1.8.0 )
Installed Updates:
Device Support:
        Prime Infrastructure 2.2 Device Pack 9 ( 9.0 )
ASA version is 9.4(1)
I have seen some posts regarding "#" in banners, but there are no banners. Any ideas?
Krzysztof
0 Replies 0
