MRTG is not Update !
vnescapehoya
Hi all !
I installed Mrtg for: Contivity 600 and some Cisco switch 2950. It was OK.
But now, diagrams of Cisco 2950 switches are not update, and I can access to these switches through browsers although username & Pass are correct!
No problem with Contivity 600 diagram, it's still ok!
Pls help me ! Thanks a lot!
dpopli
Check if snmp traps are still reachable to machine on which you installed MRTG
Also check if perl is running
