11-17-2021 10:26 PM
When we try to ping multicast group IP 239.1.2.3, we're getting reply from the receiver within the site.
But, when the receiver is on a different site, only first ping is working. From the next packet, it's not working.
What is the reason for this?
11-17-2021 11:23 PM
post a schematic drawing of the setup that does not work, showing how everything is connected, as well as the full running configurations of the devices involved.
11-18-2021 03:27 AM
Denver site and Chicago sites are connected via Cisco SDWAN
- Denver WAN Edge router (10.10.10.145, DEN-EDGE-CSR) will be the default gateway for RP (10.10.10.146) & sender (10.10.10.147). It also acts as a replicator. They’re all in the same LAN
- Chicago WAN edge router (10.20.10.145, CHI-EDGE-CSR) is the default gateway for the receiver (10.20.10.146). They’re in the same LAN
Sender IP: 10.10.10.147
Receiver IP: 10.20.10.146
RP IP:10.10.10.146
When we skipped SDWAN and form GRE tunnels between the sites also, we noticed the same issue.
11-18-2021 12:13 AM
You may need MSDP i guess here, but would be nice some config and network picture illustrate how your setup done.
11-18-2021 03:26 AM
RP IP: 10.10.10.146
