Multiple ISP load balancing
swapnilsabdra
Community Member
Hi All,
I am having three ISP link at location and I want to use all of them for my outgoing Internet traffic,Can anyone help me how can I accomplish this.
SS
Nithyanandan P
Level 2
Level 2
What is the routing protocol used in your router?
Is all three links are connected in a single router?
Generally, if you add three default routes to three links with same AD, it does equal cost load balancing. Also if CEF is runnig, by default, it does per destination load balancing.
