NAT problem in the subnet entering the vpn tunnel
Maharram_Etibar
I have created a vpn tunnel between the asa firewall (ikev1) and the cisco router. the asa subnet is 192.168.100.0/24, the router subnet is 10.100.0.0/24. The VPN works fine and they can communicate with each other. But I can't NAT the 192.168.100.0/24 subnet in the asa firewall.(also I use NAT exemption command but still NAT doesn't work.) Please help me
Richard Burts
You give us a description of your issue, but very little detail to help us understand the issue. Please provide details, especially of the ASA config.
Rick
Maharram_Etibar
hostname ciscoasa
enable password ***** pbkdf2
service-module 0 keepalive-timeout 4
service-module 0 keepalive-counter 6
names
no mac-address auto
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address ***** 255.255.255.252
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.100
vlan 100
nameif admin
security-level 100
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif mgmt
security-level 0
ip address 192.168.91.2 255.255.255.0
ftp mode passive
object network Admin_nat
subnet 192.168.100.0 255.255.255.0
object network Admin_Subnet
object network Novikov_Subnet
subnet 10.100.0.0 255.255.255.0
object-group network Local_Admin
network-object 192.168.100.0 255.255.255.0
network-object y.y.y.y 255.255.255.252
object-group network Novikov_Admin
network-object 10.100.0.0 255.255.255.0
network-object *** 255.255.255.252
access-list VPN_Access extended permit ip object Admin_Subnet object Novikov_Subnet
access-list VPN_Access extended permit ip object-group Local_Admin object-group Novikov_Admin
pager lines 23
mtu outside 1500
mtu admin 1500
mtu mgmt 1500
no failover
no failover wait-disable
no monitor-interface admin
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit any admin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 8192
nat (admin,outside) source static Local_Admin Local_Admin destination static Novikov_Admin Novikov_Admin no-proxy-arp route-lookup
nat (admin,outside) dynamic interface
access-group VPN_Access in interface admin
route outside 0.0.0.0 0.0.0.0 ** 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 192.168.91.0 255.255.255.0 mgmt
no snmp-server location
no snmp-server contact
crypto ipsec ikev1 transform-set myset esp-aes esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map mymap 3 match address VPN_Access
crypto map mymap 3 set pfs group5
crypto map mymap 3 set peer x.x.x.x
crypto map mymap 3 set ikev1 transform-set myset
crypto map mymap 3 set security-association lifetime seconds 3600
crypto map mymap interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
no validation-usage
crl configure
crypto ca trustpool policy
auto-import
crypto ca certificate chain _SmartCallHome_ServerCA
crypto ikev1 enable outside
crypto ikev1 policy 3
authentication pre-share
encryption aes
hash sha
group 14
lifetime 86400
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group14-sha256
console timeout 0
console serial
dhcpd address 192.168.100.10-192.168.100.100 admin
dhcpd dns 192.168.100.2 interface admin
dhcpd enable admin
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
tunnel-group *****  type ipsec-l2l
tunnel-group ***** ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ip-options
inspect netbios
inspect rtsp
inspect sunrpc
inspect tftp
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect esmtp
inspect sqlnet
inspect sip
inspect skinny
inspect snmp
inspect icmp
policy-map type inspect dns migrated_dns_map_2
parameters
no tcp-inspection
policy-map type inspect dns migrated_dns_map_1
parameters
no tcp-inspection
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
profile License
Cryptochecksum:c899546965c255735df2995afe3a365e
: end
ASA-STDC(config)#
Why you want to NAT ASA local LAN ?
MHM
