NCS to PI 1.2 upgrade question
dszendol
Hello
I have PRIME-NCS-APL-K9 (appliance not VM). Current version is 1.1.0.58 and I need to upgrade to Prime Infrastructure 1.2
Is it possible to do this with the same HW? I have heard that the HD are to small and they have to be replaced by Cisco?
Do anyone have some information or experience about that?
regards
Darek
Rob Johnson
Cisco used to ship the appliance with just under a half Terabyte of Drive Space which could be a problem for larger installs.
For smaller installs it shouldn't be a problem.  You just won't be able to add more disk space if needed.
If the device has HW maintenance and has the smaller drive config, it could be RMAd...
