05-13-2009 02:16 PM
Hi all,
I am looking into getting HUM so we can monitor interface, cpu, device availability for our Juniper Firewalls.
Is this software capable of doing this?
Solved! Go to Solution.
05-13-2009 02:23 PM
Technically, yes. You can load third party MIBs into HUM, and poll arbitrary MIB objects. But, we do not support problems you may encounter with polling those other devices (you'd have to contact those third-party vendors).
05-13-2009 02:23 PM
05-13-2009 02:30 PM
Thanks for the prompt update....I'm kind of figured that.
We are hoping to get these into HP Openview so this may be a more viable solution if that is the case.
