Bookmark
Subscribe
1026
netconfig fail,plz help!!!
andyc2002
Sir
when I try to run netconfig in CM3.3,it will show the error message,but I remembered it didn't need password,am I right?
"===> Update Result: failed
Could not establish telnet session to device: :PGM_NM=Configuration Archive:6739:TYPE=unassigned message type::Invalid login password."
Joe Clarke
I think your mean RME 3.5 as Netconfig is component of Resource Manager Essentials and not Campus Manager. In any event, Netconfig 3.x requires an interactive session, so valid telnet or SSH credentials are required for Netconfig to work.
so how to do it,can you tell me the way?
The error indicates that you do not have the correct password entered in RME for this device. Set your attributes for this device under RME > Administration > Inventory > Change Device Attributes. Once the attributes are correct (i.e. telnet passwords and enable passwords) the Netconfig job should complete.
If you still get the same problem, you should collect a sniffer trace of the job, then open a TAC Service Request, include that sniffer trace and a show ver/show run from the device in question.
