Netconfig push out
woods8
I am trying to push out a config change via Netconfig but I get the following error message:
PGM_NM=configuration Archive:6739:TYPE=unassigned message type::invalid login password
Any ideas? I know that all the telnet passwords are generic and correct.
cheers
marcjone
Try running a 'Check Device Attributes', through RME > Administration > Inventory
If this is generating errors, then try re-entering the login credentials for the device through 'Chance Device Attributes' (in the same sub-folder) and then run a check device attributes again
You need to ensure that CiscoWorks is fully communicating with the device before running any jobs
If CiscoWorks is not showing any problem through 'Check Device Attributes', please give details of your RME version, OS version, Device Type for the job you are trying to configure and the IOS/CatOS version running on the device
Also, see the following message on the Forum detailing a similar problem:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd6b6c1/1
Marcus Jones
I have re-inputted my telnet and enable passwords for all devices via RME>Admin>Inventory>change device attributes and netconfig roll outs work a treat!
When "adding devices" my original csv import file may have been corrupted?!
Thanx for the help Marcus - Very much appreciated.
