Netflow Best Practices
Thomas Yarger
Level 3
Level 3
All,
I have a customer using PRTG as their monitoring tool/collector and their network has limited bandwidth. I wanted to know if there are any documents relating to fine tuning timeouts/caching/TTL's? I couldn't find any that addressed my concerns. The configuration I've been using is below. Thanks! Best.
flow record PRTG
description Netflow Record
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect transport tcp flags
collect counter bytes long
collect counter packets long
flow exporter PRTG
description Export to PRTG
destination 192.168.0.165
source Vlan1
transport udp 2055
flow monitor PRTG
description Netflow Monitor
exporter PRTG
record PRTG
sampler PRTG
description Netflow Sampler
mode random 1 out-of 50
casanavep
Level 7
Level 7
Are they trying to graph via NetFlow for realtime usage graphing, then be able to drill into those graphs? If so, make you cache timeouts 60 seconds:
FNF Exporters set to:  template data timeout 60
FNF Monitors set to:  cache timeout active 60
These are the settings I typically utilize.  If not, utilization can be really off from reality when looking at flow graphs.
Cheers,
--Pete
casanavep
Level 7
Level 7
Cheers,
--Pete
Hey Pete,
Can you elaborate on what each of those timeouts are for? I’m trying to better understand the nuts & bolts of Netflow.
Thanks again!
