Netflow configuration on 4510 switch
bruenjo11
Hi everyone,
I have a 4510 with sup7e and I would like to deploy netflow on this switch. The network will contain the 4510 switch where there will be 4 blades installed, each blade contains a separate Zone (vlan) . These 4 zones will then trunk upto a firewall via ten gig link over sub-interfaces. There will be an ip address assigned to each vlan on the 4500 switch but there can not be routing enabled between the vlans on the switch. If anyone could describe or show if it is possible to configure netflow with this scenario, it would be very much appreciated.
Marvin Rhoads
You will need the IP services (or above) image with the Sup 7E on a Catalyst 4k. Assuming you have that, I believe you can use flexible Netflow and set up a separate flow exporter with each of your zones' SVI as the source.
See this guide: link.
hi Marvin,
thanks for your response. I was wondering if anyone has configured netflow in a similar scenario using the switch and supervisor mentioned. I am currently in the process of putting a build of materials together and I would like to be as sure as I can before placing the order that I will be able to get netflow to work as described previously.
