Netflow engine 5.0.2 and sizing server
j.canastero
I installed the NFC version recently, in order to collect the flows of around 160 routers, and I had to create near 884 filters and aggregators. My question is: if I have a Solaris server with 2 processors of 400Mhz and RAM 2 GB, it is possible that the equipment has interruptions or stop the services
When I enter the option of reports, is too slow.
What are the memory values that would be the optimal ones to setup in the file /config/nfcmem?
What other parameter is necessary to review of OS and the application netflow?
thanks in advance
J.Canastero
5 Replies 5
didyap
Level 6
Level 6
Exporting a large number of flows can degrade the router and Netflow Collector performance. To decrease the load, refer to http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a7618.html
To aggregate the flows, refer to http://www.cisco.com/en/US/products/sw/netmgtsw/ps1964/products_implementation_design_guide09186a00800d6a11.html#wp1031105
Jan Nejman
Level 3
Level 3
Dear Mr. Canastero,
can you more closely specify what amount of traffic is monitored or how many flows generate
your routers... Our company developed a Linux based Netflow monitoring software. We recommended 3Ghz Pentium 4 with 1-2GB RAM for processing 800 mil flows/day. (number of flows depends on network traffic character and traffic volume).
Jan
Caligare Co.
http://www.caligare.com
We are collecting around 1720000 flows/day
Jesus Canastero
I think that your processor cannot be utilized by netflow traffic. Try to find which process uses your CPU or disk.
Jan
Caligare Co.
hello Jan
Using prstat on solaris the nfc process use almost 50% from CPU0, and I have configured the nfcmem file as follows
collector min=640M max=768m
Webmem min=256 max=512
cnsxml min 256 max=512
genreport min=256 max=512
re_mem min=256 max=512
UDP_READER_POOL_ENTRIES 70000
Jesus Canastero
