Netflow Monitor Record changed, Exporter not exporting new template
matthewlacomb
ISR4331 16.03.06 - updated a Netflow monitor record; inspecting packet captures the new record is not in use.
sho flow exporter templates det
Flow Exporter Flow-to-collector:
  Client: Flow Monitor My-netflow
  Exporter Format: NetFlow Version 9
  Template ID    : 258
  Source ID      : 256
  Record Size    : 51
  Template layout
  _________________________________________________________________________________________
  |                           Field                             |  Type | Offset |  Size  |
  | ipv4 source address                                         |     8 |     0  |     4  |
  | ipv4 destination address                                    |    12 |     4  |     4  |
  | ip tos                                                      |     5 |     8  |     1  |
  | ip protocol                                                 |     4 |     9  |     1  |
  | transport source-port                                       |     7 |    10  |     2  |
  | transport destination-port                                  |    11 |    12  |     2  |
  | transport tcp flags                                         |     6 |    14  |     1  |
  | routing source as                                           |    16 |    15  |     2  |
  | ipv4 source mask                                            |     9 |    17  |     1  |
  | interface input snmp                                        |    10 |    18  |     4  |
  | routing destination as                                      |    17 |    22  |     2  |
  | routing next-hop address ipv4                               |    15 |    24  |     4  |
  | ipv4 destination mask                                       |    13 |    28  |     1  |
  | interface output snmp                                       |    14 |    29  |     4  |
  | flow direction                                              |    61 |    33  |     1  |
  | flow sampler                                                |    48 |    34  |     1  |
  | counter bytes                                               |     1 |    35  |     4  |
  | counter packets                                             |     2 |    39  |     4  |
  | timestamp sys-uptime first                                  |    22 |    43  |     4  |
  | timestamp sys-uptime last                                   |    21 |    47  |     4  |
Even though the flow exporter shows that "flow direction" is in the template, a physical packet capture doesn't show us that field in the template.
sho run | s flow
flow record Test_Record
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match flow sampler
 match flow direction
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect ipv4 source mask
 collect ipv4 destination mask
 collect transport tcp flags
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow exporter Flow-to-collector
 destination 10.1.1.1
 source Loopback0
 transport udp 2055
flow monitor My-netflow
 cache timeout active 60
 record Test_Record
 ip flow monitor My-netflow input
 ip flow monitor My-netflow output
Any thoughts?
Edit:  Doing testing found this when changing from "netflow-original" to "Test_Record":
Apr 18 13:32:57.695: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: SIP1: fman_fp_image:  [FNF Object] type:MON_FDEF_BIND name:My-netflow-0-Test_Record-3766897112 fnf-id:2000002 real-id:2 info:mon-id:2000001 flow-id:2000002 download to DP failed
Interesting.... maybe a bug?
matthewlacomb
16.03.08 exhibits the same behavior; as does 16.06.05.
There seems to be very similar bugs online showing your alert output ,were on isr4300-universalk9.03.16.07b.S.155-3.S7b-ext.SPA.bin its been stable for us , you could test that or TAC it get the exact bug ID and go from there
Removing and reapplying the FNF on 3650 running 16.6.2 many times can cause the exporter to fail.
CSCvi03188
