Netflow on WS-C4500X-16 with PRTG
Simon1337
Hello
How can I find out if netflow is supported? It is needed in conjunction with PRTG.
Model: cisco WS-C4500X-16 (MPC8572) processor (revision 9)
Firmware: IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.08.04.E RELEASE SOFTWARE (fc2)
PRTG: NETFLOW V5 & NETFLOW V9
Many thanks
Mark Malone
yes its supported heres output from my 45x switches in VSS running 3.8.7 running ipbase
#flow ?
exporter Define a Flow Exporter
loc-rate Set Loss Of Confidence shaping rate
monitor Define a Flow Monitor
record Define a Flow Record
xxxxxxxxxxxx(config)#do sh ver | i 03
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.08.07.E RELEASE SOFTWARE (fc2)
System image file is "bootflash:cat4500e-universalk9.SPA.03.08.07.E.152-4.E7.bin"
Thank you very much for your reply. I also have this information. According to cisco the version "Flexible NetFlow" is supported. But what about Netflow V5 & Netflow V9 ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/fnf.html
no thats whats supported above only , the other versions are not available once flex is there
(config)#ip f?
finger forward-protocol ftp
