netflow port
andyc2002
default netflow port is udp 9996,can I change to udp 161?
spilkinton
Level 2
Level 2
Specify the port number after the destination IP
ip flow-export destination {hostname|ip_address} {port number}
Changing the default port is OK but changing it to the port of another protocol is maybe not a good idea.
If it is to get it through a firewall then keep in mind some firewalls now check if packets are valid. It may see that the packet is not what it's type field indicates and drop it.
Cheers,
Michel
