Netflow
gpan667788
Level 2
Level 2
Greeting,
Does anyone have any recommendations for any NetFlow analyzer products in the market?
thanks,
Gene
m.pandey
Level 2
Level 2
netQOS... but all depend upon your need also...
There are some free tool too but one need to customized that as per need. cuflow and some other combination can build a good monitoring too...
With best regards,
Mani
terry_bjorke
Community Member
Cranog has one as well. But my personal choice was NetQos.
peter.nowack
Community Member
Hello, we are using Caligare Flow Inspector.
We were choosing from 5 products. Caligare have great filtering and application recognization. It is nice that you can set up which fields do you want to store and how many tables do you want archive for post mortal analyzis. We also used it for finding infected stations in our network. Big disadvantage is difficult installation. 😞 Crannog and Manage engine are easy to install, but with less functions. Nice alternative is PRTG. We tested free tools as CESNET netflow monitor, flow-tools, cflowd, but they are useable only for small networks. Commercial applications are much more better. 🙂
Peter
