Network Assistant connect button not working on OSX
lasalp
I have a problem with the Network Assistant 6.3.4 application on OSX 10.15.7. I can install and launch the application without problems, but most of the buttons don't actually do anything. As the application starts, the top bar and a login window are shown. If I enter my Cisco login credentials the window closes nothing happens. The same if I click on the connect button. Some other buttons work (for example help). I tried to run the Assistant with Java 16 and then 11, but the behavior is always the same.
pieterh
did you perform this step from the release notes?
Note
 To run Network Assistant on MAC OS X (10.7 Lion and above), follow these steps:
- From the System Preferences window, select Security and Privacy.
- From the Security and Privacy window, select the General tab and click Anywhere.
