Using Prime Infrastructure for high temp alerts
spfister336
Level 2
Level 2
We have issues some times with high temperatures in the locations where our switches are located. We would like to have Prime poll the temperatures reported by the switches and generate alerts when they exceed the threshold.
I've tried to set this up, but I'm having some trouble figuring it out. Can someone give me a summary of the steps I'll need?
Mark Elsen
- Not sure  if this can be done easily with polling , but you should forward syslog-events, and traps to prime, for snmp-traps it is advisable that all categories are enabled. Then temperature problems should arrive as alerts (too) in Prime.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
PI or DNAC do not support temperature alarms.
You will need to find other products to do that.
