Network Assistant
cantorb
Community Member
I want to play around with the Network Assistant just to see what its all about. I've downloaded and installed the *.exe file but I can't seem to connect to any of my devices. I've got a bunch of new 3750s in the network that I *think* will support the Network Assistant but everytime I try to connect I get "Connection Refused". Is there a command that needs to be issued on the 3750s in order for me to use this tool? Thanks in advance...
bc
ebreniz
Level 11
Level 11
CDP must be enabled and http server in the switch should be enabled. CNA uses shttp to communicate and uses a community which uses SSL.
http://www.cisco.com/en/US/products/ps5931/index.html
