Networking
lorareyes93
Community Member
I suspect that is what your instructor is expecting of you.
Here is a start for you on installing WAN card.
then put in cables
Once done click on router.
(type NO for configuration setup)
Enable
Configure Terminal
int fa0/0
and put in ip address and mask  to switch
There are worlds out there where the sky is burning, where the sea's asleep and the rivers dream, people made of smoke and cities made of song. Somewhere there's danger, somewhere there's injustice and somewhere else the tea is getting cold" Dr Who
6 Replies 6
pmckenzie
Level 8
Level 8
YOU need to open packet tracer and click and drag routers-pkt tracer.PNG switches and pcs onto your screen and then connect with the appropriate cables.
Thank you but could you help me also with the configuration?
then put in cables
Enable
Configure Terminal
int fa0/0
I'm done, can we proceed to the configuration?
have a look at this guide
https://www.computernetworkingnotes.com/ccna-study-guide/configure-cisco-router-step-by-step-guide.html
Also You Can Check The Article Given Here For Step-by-step Guide. Cisco Step-by-step Guide
