09-25-2006 02:20 AM
Hi Expertise,
Cisco works 2000 getting very slow during login time as well as browsing time. what could be the problem.
Thanks & rgds...
Ashish Singh
09-25-2006 05:06 AM
What are the server hardware specs?
Also, are you using SSL to connect?
Any other sites slow from this browser? Is this happening on one or all clients?
09-25-2006 06:52 AM
Thanks 4 reply
i hve very higher end server thats not a problem.m accessing through http://serverip:1741. Through browser other site working properly.M accessing through http on server itself where i installed nms.
I think some log problem, i got some log clear option at cisco but its not effective.
09-25-2006 10:57 AM
Which version of CiscoWorks LMS is this specifically and on which OS? Are you using IE or Mozilla?
Also, if you clear the browser cache and Java cache does it improve at all?
09-25-2006 10:13 PM
Thanks 4 Reply !!!
M running nms on windows 2K terminal.
Using ie-6.0
Ya i already cleared the java & browser cache but problem presist same
DFM-Ver 1.2
RME-Ver 3.4
Campus Manger- Ver 3.2
N genius real time- Ver 1.4
Cd One Cisco Works Include Cisco Viez- 5th Edition
Rgds..
Ashish Singh
09-26-2006 12:59 AM
See the workaround in CSCdz24611. By enabling keep alive in httpd, you may dramatically increase performance. In addition to this, you can try setting HostnameLookups to Off in this same httpd.conf (if not already done).
09-26-2006 01:49 AM
As per CSCdz24611, This is regarding problem 'slow login through remote loacation & working fine at local machine.'
My problem it s take lot off time at locally login itself
Ashish
09-26-2006 07:10 AM
The problem can still be due to disabled keep alives regardless of what machine is the client. Running the client on the server does bring the additional cost of spinning the CPU for both Java applets as well as servlets/applications. You should also be mindful of the CPU and memory usage.
