NMS System FCS Error, discard monitoring questions
Key12
Hello. my name is Key.
I am using NMS System PRTG.
I want to know interface FCS error and discard counte through NMS System PRTG.
Product n7k-C7009
             n5k-C5672UP
             n5k-C5548UP
             n5K-C5596UP
             WS-C3850-24XS
             WS-C2960X-48TS-L
I checked through the homepage, but I do not know the OID value.
Above products I want to know the FCS error and discard counte OID value.
please answer about my question.
Thanks.
Kirk J
Greetings.
Try using 1.3.6.1.2.1.10.7.2.1.3 for FCS, and 1.3.6.1.2.1.2.2.1.19 for out discards.
Kirk...
Thanks!
Xmit-Err, Rcv-Err Can you also know OID value ???
Please let me know the OID value.
I'm in a hurry. T_T...
Kirk J
For xmit-error try: 1.3.6.1.2.1.2.2.1.20
For ifInErrors try: .1.3.6.1.2.1.2.2.1.14
.1.3.6.1.2.1.2.2.1.20
ifOutErrors OBJECT-TYPE
	-- FROM	IF-MIB
	SYNTAX		Counter
	MAX-ACCESS	read-only
	STATUS		Current
	DESCRIPTION    "For packet-oriented interfaces, the number of
               outbound packets that could not be transmitted because
               of errors.  For character-oriented or fixed-length
               interfaces, the number of outbound transmission units
               that could not be transmitted because of errors.
ifInErrors OBJECT-TYPE
	-- FROM	IF-MIB
	SYNTAX		Counter
	STATUS		Current
	DESCRIPTION    "For packet-oriented interfaces, the number of inbound
               packets that contained errors preventing them from
               being deliverable to a higher-layer protocol.  For
               character-oriented or fixed-length interfaces, the
               number of inbound transmission units that contained
               errors preventing them from being deliverable to a
 Here's the the whole table:
ifIndex .1.3.6.1.2.1.2.2.1.1
ifDescr .1.3.6.1.2.1.2.2.1.2
ifType .1.3.6.1.2.1.2.2.1.3
ifMtu .1.3.6.1.2.1.2.2.1.4
ifSpeed .1.3.6.1.2.1.2.2.1.5
ifPhysAddress .1.3.6.1.2.1.2.2.1.6
ifAdminStatus .1.3.6.1.2.1.2.2.1.7
ifOperStatus .1.3.6.1.2.1.2.2.1.8
ifLastChange .1.3.6.1.2.1.2.2.1.9
ifInOctets .1.3.6.1.2.1.2.2.1.10
ifInUcastPkts .1.3.6.1.2.1.2.2.1.11
ifInNUcastPkts .1.3.6.1.2.1.2.2.1.12
ifInDiscards .1.3.6.1.2.1.2.2.1.13
ifInErrors .1.3.6.1.2.1.2.2.1.14
ifInUnknownProtos .1.3.6.1.2.1.2.2.1.15
ifOutOctets .1.3.6.1.2.1.2.2.1.16
ifOutUcastPkts .1.3.6.1.2.1.2.2.1.17
ifOutNUcastPkts .1.3.6.1.2.1.2.2.1.18
ifOutDiscards .1.3.6.1.2.1.2.2.1.19
ifOutErrors .1.3.6.1.2.1.2.2.1.20
ifOutQLen .1.3.6.1.2.1.2.2.1.21
ifSpecific .1.3.6.1.2.1.2.2.1.22
Kirk...
