NTP sync problem - "configured, authenticated, insane, invalid, unsynced, stratum 16"
nedeljkovicd
Hi everybody,
i'm configuring remote office router, IPSec over MPLS connection, and ntp can't sync with ntp server.
RMToff#sh ntp associations detail
10.32.1.11 configured, authenticated, insane, invalid, unsynced, stratum 16
ref ID 0.0.0.0, time 00000000.00000000 (00:00:00.000 UTC Mon Jan 1 1900)
our mode client, peer mode unspec, our poll intvl 64, peer poll intvl 64
root delay 0.00 msec, root disp 0.00, reach 0, sync dist -2515.213
delay 0.00 msec, offset 0.0000 msec, dispersion 16000.00
precision 2**5, version 3
org time D714956E.8B2A722A (11:20:14.543 UTC Wed May 7 2014)
rcv time D714B158.1C9A76DD (13:19:20.111 UTC Wed May 7 2014)
xmt time D714B158.19A8C69C (13:19:20.100 UTC Wed May 7 2014)
filtdelay =     0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
filtoffset =    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
filterror =  16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
RMToff#sh clock
.13:20:57.351 UTC Wed May 7 2014
I suppose that differecnce between org and rcv time shoudn't be so large, but have no idea what causes it. Any ideas?
Thanks in advance!
Marvin Rhoads
I suspect it's because the client sees the server at stratum 16 (not synced with a valid source).
To see more precisely why the client isn't syncing ("insane" server), you can "debug ntp validity" and see which of the sanity checks is failing.
Here is a good reference article for that and other troubleshooting tips.
You could also try manually setting your local clock and then seeing if it syncs. I have seen some devices not sync if the offset is too great.
Mark Ruhland
Yes that is correct, if the host time is more than 1024 seconds off from the received time it will mark the source as insane.
