OID show spantree blockedports
RJHoldi13
Can anyone point me to the OID where i get the spantree blocked ports of a vlan ?
Thanks in andvance, Reinhold.
steve.busby
Level 5
Level 5
You can try OID 1.3.6.1.2.1.17.2.15.1.3 from the BRIDGE-MIB.
See this link for possible values and their meaning:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.2.1.17.2.15.1.3
Steve
Hi Steve,
thanks a lot for the answer. the listing of blocked ports of the default vlan 1 is fine. do you also know a solution to get the same for any vlan ?
like "show spantree blocked " ?
thanks again for reply, Reinhold.
