4G router is good if you have good signal from Provider, if not suggest to reply on DSL connection.
you can use any old PC with multi USB cable to connect all the switches to manage, since this PC behind FW, it is secured
This is the cheapest solution i can think of right now.
May be wait for others welcome comments.
