Out of synch
rdanevich
How do I clear out these entries from RME failed synch archive? see attached pic.
Also, is it possible to archive a 1900 series switch? I cannot get a successful archive on these older devices. Telnet failed authentication 3 times.
mchin345
Level 6
Level 6
you should be able to do this using job purge, check out the following link for more information :
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_user_guide_chapter09186a0080352b7d.html#wp1214348
I ran a Purge for Archive Management Jobs. This did not do it.
This is some sort of dynamically created report when I click on the number, in the "Failed" row under the "No. of devices" column of the "Configuration Archival Summary"(DcmaArchiveSummary.do) page in RME.
Reviewing the picture I pasted you'll see that there isn't a "Device Name" in the report. In the past I've corrected the errors as reported, re-submitted the sync archive and the device was removed from the report. Then I had a device name to go by. I have no device name to go by, the data is old and irrelivant, or mis-labled. Where is this bad data being held so that I can "clean-up" the dynamically generated report? Garbage in = Garbage out.
I appreciate your attempt to assist me with this problem.
