Common services - Device Credentials
poppj
Level 2
Level 2
Common Services ver. 3.0.4
- Is there a method to change the global property for the ?primary username? for a group of devices? It seems to be the only field that cannot be changed ? default is ?Value Exists?.
David Stanford
Select your group of devices in the Device Summary window and select edit. In the next page that loads, don't try to highlight individual devices. You can then proceed to edit attributes you want for the group.
miheg
Level 9
Level 9
You can change it
If it says value exists it just means the field is not empty.
You just type the value you want in that field.
Cheers,
Michel
David Stanford
thanks - yes all I had to do was delete the "value" and supply the user.
