Packet Tracer IoT devices?
kiyolsakie6
Has anyone tried creating IoT setups in PT? I tried to make one for fun yesterday and I didn’t get very far at all. I tried using a smartphone to operate devices, for example, or even just use a rocker switch to turn on sprinklers and nothing ever worked.
I even used the special IoT cabling and mcu things.
Martin L
not yet; there should be some samples under PT File menu, open samples. Also, check under Help menu; otherwise, look around on Net academy site and the Internet.
Regards, ML
**Please Rate All Helpful Responses **
