Packet Tracer Ping/ frame dropping issue.
ProphecyGaming
Hello cisco community fourm. I am trying to figure out this issue with my packet tracer project but I am unable to figure out why I cannot ping as well as all broadcast frames are dropping across my server, router, and PC.
Here is a brief overview of what my idea setup is supposed to be aiming for:
Setup vlans PC_LAN, SVR_LAN, VoIP_LAN.
The switch should be able to have a phone and PC plugged into the same port with the phone on its correct vlan. Be able to ping from PC to SVR.
Put the phone on a separate vlan
Do appropriate tagging.
1 pc 1 SWITCH 1 ROUTER 1 SERVER 1 IP Phone Setup IP address: 10.0.0.0 Subnet mask: 255.0.0.0
Switch gigabitethernet0/1 – router gigabitethernet0/0 Switch fastethernt0/2 – Server fastethernet0 IP Phone switch port - switch fast ethenet0/3 IP Phone PC port – PC FastEthenet0
Do not setup the PC or the phone statically but do DHCP. Set up the router to accept DHCP.
P.S I have attached my packet tracer project file through a mediafire link. please view it and give me some pointers
https://www.mediafire.com/file_premium/xigmmal0r5evgf9/Project.pkt/file
 On the file attached, PC can ping server and phone and server can ping both. All seemed rigth to me except by the fact that Vlan1 was in shut down. I had to unshut the vlan 1 in order to ping the phone. In real environment, I believe this could be fixed by puting vlan 30 as native but it seems this resource is not available on PK.
" I am trying to figure out this issue with my packet tracer project but I am unable to figure out why I cannot ping as well as all broadcast frames are dropping across my server, router, and PC. "
 Ping is ok on the attached file but broadcast will be always dropped by routers. This is the expected behavior.
Thank you for your help! I guess I just needed another pair of eyes to scare it into working right.
