packet tracer problem
4sundown
I have the problem with packet tracer config with this message
% Unknown command or computer name, or unable to find computer address.
pls i need help
Harold Ritter
Hi @4sundown ,
This error message means that the command you entered is not recognized. What is the command you entered to trigger this error message?
Martin L
Sounds like DNS resolution problem if u got this in a browser; check DNS settings and DNS server
You can attach PT file here but it must be in a zip format;
Also check CLN community PT and CCNA forums at
https://learningnetwork.cisco.com/s/communities
https://learningnetwork.cisco.com/s/topic/0TO3i0000008jYHGAY/ccna-certification-community
https://learningnetwork.cisco.com/s/topic/0TO6e000000WEorGAG/packet-tracer
Regards, ML
**Please Rate All Helpful Responses **
