Persistent redundant power supply OID
Salvatore Conte
am using Cisco IE4010 dual power switches, version of FW 152-7.E3
I have noticed that on some switches, the OID of the second power supply often changes.
Is there a way to make OIDs persistent?
BR
6 Replies 6
  Initially this does not make sense but I believe in everything. Can you share where are you seeing the OID changing?
The second feed of the screenshot, changes randomly on reboot. It doesn't always happen, but the final value changes .1.3.6.1.4.1.9.9.13.1.5.1.4.1086
 This is probably a Bug.  I´d try change the version or call cisco TAC.
marce1000
 - As stated already provide output/example(s) sometimes  indexes/OID's  can be made persistent , but applicable to interfaces only (normally) :
         https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/snmp_if_index_persistence.pdf
 M.
Hi Marce
Thanks for your feedback.
I have a network of 14 dual power IE4010 switches, firmware version 152-7.E3.
Only on some switches, it happens that by restarting the switch, the OID of the second power supply changes and therefore I lose the SNMP communication (see screenshot)
Before reeboting
If you need more information, please ask me
Salvatore
if 'rebooting' can be replaced with 'reseating', the bug below could apply.
IE-4010 Power supply OID change after re-seat
CSCvh01635
Customer Visible
Notifications
Save Bug
Open Support Case
Description
Symptom:
SNMP OID used to access the PS MIB changes whenever they are pulled out and re-seated into the slots
SNMP query from management application might fail after taking out and plugging in the power supply module due to OID change.
Conditions:
Impacts IE-4010 and IE 5000 switches with field replaceable power supply modules installed with IOS version 15.2(6)E1
Workaround:
none
Further Problem Description:
Below example provides an illustration of the problem :
Original state - Both power supplies inserted :
$ snmpwalk -c TEST "IPaddress" 1.3.6.1.2.1.47.1.1.1.1.7.1054
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1054 = STRING: "Power Supply 1"
$ snmpwalk -c TEST "IPaddress" 1.3.6.1.2.1.47.1.1.1.1.7.1092
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1092 = STRING: "Power Supply 2"
After re-seating power supply 2:
$ snmpwalk -c TEST "IPaddress" 1.3.6.1.2.1.47.1.1.1.1.7.1072
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1072 = STRING: "Power Supply 2"
OID for power supply 2 changed to 1.3.6.1.2.1.47.1.1.1.1.7.1072 which was originally 1.3.6.1.2.1.47.1.1.1.1.7.1092
Known Affected Releases (1 of 1)
15.2(1.0)IEC2
Known Fixed Releases (3 of 3)
15.2(6.1.8i)E2
15.2(6.0.95i)E2
15.2(6)E2
