PI 2.2 - C892 - Clients and users not monitored
lauresfrank
Dear Community,
I have a small site with one Cisco892FSP (IOS 15.5T2) with a lot of connected clients to its 8-port switch. I successfully added the router/switch to PI2.2 (managed). The SNMP config on router is quite easy with SNMPv2 enabled and a RW community.
The problem is that the clients don't show up under "Monitor->Clients and Users". It is just empty.
- Which MIB does PI use to get clients and users? Maybe it is not supported on routers?
- Any other idea?
5 Replies 5
AFROJ AHMAD
Hi ,
Go to Admin >background task   and make sure "Wired Client Status"  is ENABLED
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Yes, it is enabled by default (See attachment). So this is not the reason for the problem. But thanks anyway.
How about the client statics for other devices like switches  ?
Dear Afroj,
yes other switches work. So this must be a C892 related issue? See Attachment.
Thanks for your support.
as far as I know ,client and user information will not work for router :(
Thanks-
Afroz
Thanks-
Afroz
- See more at: https://supportforums.cisco.com/discussion/12505971/pi-22-c892-clients-and-users-not-monitored#sthash.pe4sVZUR.dpuf
Thanks-
Afroz
Thanks-
Afroz
