PIX 501 Internet Usage Monitoring
augnevenok
We would like to monitor Internet usage on per-user basis, we have PIX 501 and users accessing the Internet via NAT.
What are the options?
As 501 does not support Netflow, can I use Syslog or SNMP getting usage stats?
Thank yoou.
Kind regards,
Alex
Jan Nejman
Level 3
Level 3
I'm worry, that you are not able to do a user monitoring on this kind of device. A SNMP gives you information about interface utilisation, but no user regarding information... Could you use any netflow capable switch before/after PIX? It is the first solution. But you lost information about real source user due to NAT. The another one solution is to use two switches (or a transparent netflow probes), the first one on ISP side and the second one in your internal network...
Kind regards,
Jan Nejman
Caligare Co.
http://www.caligare.com/
